Captain Ron
- On the horizion
It means whatever you want it to mean.
Questioning?
Don't call me God Troy. You should know better.
--ron
Questioning?
--ron
yes, yes i do:laugh: i love you ron.:loveu:Captain Ron said:Don't call me God Troy. You should know better.
--ron
Mr.OverKill said:yes, yes i do:laugh: i love you ron.:loveu:
Mr.OverKill said:ok, so that means?????? well .......... 3* of rotation???? what ????common sense is really uncommon, how about a hint, dispense with some of your God like insight...:dunno: :dunno: :dunno:
XJEEPER said:You nailed it, Jes.
Goatman said:Jeff, I do remember the days of disconnecting my front driveshaft for every trip to and from the trail. I actually had some plummers tape and a wing nut and kept a 5/16 wrench handy to make it easy.
--ron
Goatman said:I did find that the XJ drove just fine with as little as 3* of castor.
XJEEPER said:3* at 75mph still has more vibes than I care for. gonna twist em.
Uni-bearings have a few benifits also. The ease of changing an axle being the biggest.Goatman said:Those nifty Warn 5 on 4.5" hubs have proven to be pretty durable.
All it takes is money.
Goatman said:Yep, that's true, if you're starting from scratch. If you already have money tied up in a well built turdy and you have driveline vibes, then it's something to consider.
The alloy stubs could be sold to cover a little bit of the cost.
My caster was 2.00*/2.15*; camber -.1.08*/-0.71* with worn out upper ball joints.bj-666 said:said endevor may be avoided by said party purchasing offset balljoints.
Handlebars said:My caster was 2.00*/2.15*; camber -.1.08*/-0.71* with worn out upper ball joints.
I figured what a great opportunity to put in some nifty 2* offest balljoints to regain some caster.
Now I have a wonderful 2.84*/2.71* of caster; -0.61*/-0.34* camber.
Jeff, want to practice on my axle?
It's not too bad at my Cherokee's maximum speed of 80mph, but I can't drive "no hands" for long. It will pull in whatever direction the road crowns towards. Crosswinds make for a white knuckle drive. I can live with it but I was still hoping to get it to track a little better.Goatman said:Alex, how did it drive with 2* of castor? I know mine was fine with 3*, but what is 2* like?
Who makes 'em? The offset uppers were from SPC.TNT said:They make offset lower balljoints now too....
