JEEPZZ
- In front of my PC
Nevada City Sparky said:Man, I wish I could put one of those in mine. Unfortunately, mines got a sunroof which is useless with a rack and living in the deep, wet woods.
Wish there was an easy way to remove and patch with a steel panel.
The WJ Grand Cherokee overhead will not work in the XJ. The WJ's overhead gets all of it's info from the body control module, included temp and compass. If you use an earlier ZJ console, only the 93-95 will display temp & compass. The ZJ 96-98 will only display compass on it, no temp since the temp info comes from the non-compatible body control module.BlueCuda said:I wonder if you coudl use one from a grand with a sunroof? I am sure the computer part works the same.
This one is from an 04 so I doubt it works but worth checking into them.
Both styles on ZJ console will not display computer/mileage functions for the same reason.
Here's a 96-98 ZJ console mounted in an XJ. It's a lot of work but it can be done. Notice no temperature readout on the display.
Here's an easier solution for a sunroof:
