Heres an update! The last to-do list grew and was dramatically modified as I learn more about this project.
Heating:
I do not like being cold. I also like traveling to cold places. I have a three phased approach to cold on this project:
- Use the 3 glowplug rear head housing available on European TDIs. I ebayed and got part # 038121145 and 03812133A which bolts up nicely. I will butcher up the extra BHW harness to build a relay setup for this and either flash a BGW s/w load onto my edc16 or have a tuner figure that out while doing the needed manual transmission conversion needed for the BHW software.
- I REALLY like the idea of Malone's dynamic EGR he has figured out. His tune basically uses the EGR only to bring the temperature of the coolant up, then shuts it off for the duration of the cycle. 99% likely to go this route.
- EBay Webasto Thermo Top. This has been purchased, and will be plumbed in when the gas tank gets swapped. This is a diesel powered auxiliary heater that brings the block up to 160f without running the engine or plugging the block in by circulating engine coolant through its boiler.
I had issues with the BHW hard coolant lines, the thermostat housing, and the motor mounts. I ended up mixing in a Dorman 902-990 (VW# 048121121B) thermostat housing off Amazon. It does not interfere with anything yet... time will tell and something will have to give. The hosing has had some iterations (combos to BEW and BHW hoses) but this is what it looks like generally speaking:
I favored the aluminum thermostat housing you can get for the 1.8t engine, but I couldn't justify the ($90) price for something that I'd immediately chop up to make fit when a replacement that does fit is $10.
The 3 glowplug head looks like this:
AC Compressor:
The stock compressor DOES NOT fit with the EVGuy motor mounts. This is not an issue for me, the VW pump was "special" and only used VW proprietary fittings and was a variable displacement design specific to VW. There are several options here. I am looking at an HD option that has the same displacement as the TDI had but has an improved head for better efficiency. The
Sanden 4660 is the current option, but I also considered Sanden part numbers 4455, 4323, 7304, and 4711. 4660 is the HD version of 4711 from what I can tell.
The stock VW compressor has the same ear to ear dimensions as the average long ear mount Sanden BUT the compressing bushing that is pressed into the rear ears takes up a 3mm difference in the mounting pads. No matter what compressor I go with, I will need to fabricate some spacer and possibly mill the accessory adapter to work.
I've been doing math on fitting a compressor. I have 185mm from the center of the forward-most tooth on the serpentine belt to the front of the motor mount to work with here. The stock compressor is 214mm long from the first tooth to the rear of the compressor for anyone wondering why it won't fit. The 4660 I favor for this swap is 192mm from the first tooth to the rear of the compressor. 112mm of body, 46.5mm of first groove to body, and a 33.4mm head. It has an 8 groove pulley, so chopping off 3.56*2, we have 184.78mm to work with. Good grief, that's TIGHT.
Next I need to calculate where that puts the ears of the compressor in relation to the alternator bracket. The stock compressor is 68.9mm from the first tooth to the bracket (rear of the front ear on the compressor). This 4660 is 53.78mm to the same point, leaving a 15.12mm gap to fill.
4660:
4255 (VW OEM):
The rear ear is 14.4mm long and is 3.3mm further back from the bracket mounting bar, since the mounting bar on the bracket is 80mm long and the 3.6mm gap left on the VW compressor is taken up with a friction compressed bushing that sleeves into the rear ear of the VW compressor. Normal Sanden 8 ear compressors do not have this. I need to cut 15mm out of the rear of the bracket, so there wont be any rear support and the rear half of the bracket mounting bar will only have 3.3mm of aluminum left after moving the compressor forward.
Here's an overhead view of my logic:
Here's my bracket plan:
Fans and AC Control:
I am using a 28mm
"temperature gauge pipe", milled the top off (read: orbital sander and 40 grit sandpaper, chucked in a vice), drilled the hole out to 13/16", and tapped it to m22x1.5 to fit the temperature sensor that usually goes in a Jetta radiator.
I also got a Volvo fan. Its like the Taurus fan everyone is gaga about BUT its brackets are FLAT and do not require excessive modification to fit everyday applications. I plan on grafting this into a stock Jeep fan shroud.
Fuel:
Fuel will be filtered through a 2um CAT or Donaldson class 8 truck filter on a Duramax filter head with an integrated priming pump and heater. I picked up a GM 12642624 filter body since it has banjo bolt fittings to make plumbing easier.
I also picked up the 68003865AB fuel pump kit for a 2000-2001 dodge 2500 with a 5.9l. It is a tad too tall. Atleast its too tall and not to short, to fix this problem, you trim the guide tubes, flair to fit, and cut the springs. In other good news, it has an aux fuel port for my Webasto built in, I only have to plumb it up. This guy has a 3/8" quick connect supply and a 5/16" quick connect return. Theres also an auxillary pickup straw for the webasto. I am thinking of replacing all of the XJ fuel lines with b100 friendly line, specifically Parker
Mounts and Adapters:
I have procured
EVGuy's Motor mounts and
engine adapter
Transmission to Engine mating progress
I got EVGuy's mounts and engine adapter as I had said I would probably end up doing earlier. Great quality! I also got a LuK 05-065 clutch kit and LuK LFW193 flywheel. The clutch in the Jeep now is about 30k old, I'm sure its got lots of life next, but with as much as I am into this project theres no sense in not just replacing it now. The flywheel on the other hand is OEM, 200k mile old.
Instruments
member Alexia has been developing a
GREAT piece of code to
emulate enough of CCD to run ALL functions of the instrument cluster with about $40 worth of hardware. I am completely onboard with using the stock cluster now! I will be building the hardware he has to do my own testing soon.
Whats left on the purchase list (in order):
- Sanden 4660
- GTC1549VZ turbo, drain, oil line, adapter plate
- Stage 2 cam, timing belt, lifters, BSM delete.... blah blah
- NPG Racing steel oil pan
- downpipe, misc exhaust parts
- b100 fuel line
- AX15 shifter out of a Dakota to bend up (the engine moves the transmission 4" forward)
- Novak transfer case shifter
- Coolant hoses
The to-do list:
- finish buying parts.
- tandem pump, crank seals, BSM delete, cam, lifters, timing belt, water pump, rollers
- driveshafts will change - need to calculate these. Looks like a handful of OEM applications will work for me, the 2.5l front shaft is looking good.
- figure out intercooling - still on the fence over water-air or water water
- figure out air filtration - looking like a Donaldson PSD
- plumb cooling and air, atleast roughly before pulling the 4.0
- FINISH wiring cleanup. I want the TDI harness close to standalone, then splice it into a 4.0 engine harness.
- rebuild tandem pump - I have a rebuilt pump minus a seal
- Still debating the snorkel.
- figure out if tank venting needs to change
- route fuel lines, remove EVAP when the engine is pulled
- check fuel filler neck to see if it needs to be modified to work with diesel spouts
- Route A/C lines
- Mount A/C compressor
I just bought my first house. In the process, my wife and I decided we would remodel just about every aspect of it, leaving me with no garage till thats done some time in the next 3 months. This has severely slowed progress... but in the Seattle market, it made more sense than renting, since my mortgage is less than rent was!
