JcrOffroad Sliders
jcroffroad
www.jcroffroad.com
Kalamazoo, mi
With two styles to choose from! Both of which built right here in Michigan, USA.
Classic Rock Sliders - XJ Cherokee
These sliders are designed for hardcore off-road abuse. The main tube is made with 3"x2" boxed tubing with a .188" wall and the side tubes are 1.75" x .125 wall. They bolt to the pinch seam with 5 bolts and the main legs off the sliders mount with 8 bolts to the uni-body. Giving you a total of 13 bolts PER SIDE!
Some drilling required, but easily installed. These sliders are created by professional fabricators; therefore the welds, fitment, and attention to detail are second to none.
OR
Crusader Sliders - XJ Cherokee
JcrOffroad’s Crusader Sliders are like nothing else on the market and are the end all rocker slider solution for your Jeep Cherokee! Save more than 2” in ground clearance and nearly 20lbs over the standard issue boxed tube sliders. The Crusader Sliders are CNC formed in house here in the USA from 3/16” thick steel for maximum rigidity. The unique mounting design ties the sliders into the rocker, the pinch seam and the main uniframe using 35 fasteners PER SIDE; making them the most secure sliders on the market!
Get yours today!
