ISO: 4"-4.5" Lift for 2000 Cherokee
LBC970
Colorado
I'm looking for a lift for a 2000, somewhere in the 4.5" range, thought I would check on here before springing for some shiny parts.
Long or short arm doesn't matter to me. Shocks or no shocks is fine. I do not want blocks in the rear.
Thanks!
Have 4.5" Zone Off-road lift, it's on 98 XJ that was rear ended.
Includes rear leaf springs and extended shackles, transfer case drop, front coils, lower control arms, front Rancho shocks. No rear shocks. $400. Lift is still on Jeep but can pull it next week if interested.
I'll PM you now, thanks!
Have a bunch of different XJ stuff for sale....
1. ZJ tie rod upgrade $30
2. Drag Link $30
3. Drag link & ZJ tie rod together $50
4. 2 Rough Country 4.5" lift lower adjustable control arms; $60 each
5. 2 Rough Country 4.5" lift upper adjustable control arms; $50 each
6. Spare front drive shaft, 29" ride length; $50
7. 4.5" Rough Country Leaf Springs $125 for the pair; at least two bushings could use replacement.
8. Dana 30 Diff Cover $25
9. Chrysler 8.25 Diff Cover $25
10. Rotors $20 each
11. Dana 30 Driver Side Axle Shaft (the short shaft) $50
2. Drag Link $30
10. Rotors $20 each
Where are you located? I'd take the ZJ tie rod and drag link off of ya, as well as the 8.25 cover (factory or aftermarket?).
EDIT: I'm a dumbass, your in COS. I may be making a drive to Texas later this week, I will let you know if I do, I can swing by and pick them up.
