Internal to external slave
90Blue_XJ
I have heard rumors of there being a way to convert the internal donut type slave cylinder to the external fork activated slave but as yet have not found anything written. Does anyone know if this is a myth or can you do something with the original internal bellhousing to convert it?
I know that you can swap in a newer style bellhousing but that is not a real conversion. Can this be done???
I don't know of a way.
You need a place to mount the slave, you need a fork & throwout bearing, and you need a pivot for the fork.
-Ron
Thanks Zuki, I will keep looking. I can get the aluminum welded if needed, but don't really know what needs to be welded and to exactly where it should be welded.
You need:
- Front Bearing Retainer
- Bellhousing and associated parts (clutch fork, pivot ball)
- Replacement hydraulics
It can be done, you just have to find the parts. From some of the digging I've done, they're not very cheap, either.
NB: The NV3550 uses the same bellhousing as the AX-15e, but I'm fairly sure the front bearing retainer is different. Still, it will open up your search area slightly... (The Dakota bellhousing will not work with the XJ - the Dak has the Dodge LA-block pattern, and the XJ has the AMC V8 pattern. However, the Dakota V6 did seem to follow the XJ as far as transmissions go...)
