POLAR_JEEP_04
- Ohio
That’s a great deal mac! Maybe my next purchase.
I've had this one for over 12 years.
https://www.menards.com/main/tools-...-air-compressor/sl3706056/p-1444439609007.htm
Hard to beat the bang for buck.
mac 'worth being 220 volt' gyvr
Would like to know a bolt in steering upgrade any of you would reccomend ? I’ve looked for days and I still have no idea what to order .
I need interior stuff too...might be painting this one anyway. I'll pm youI just scrapped one but have 3(all red) more, plus 2 WJs and 4 XJs for parts. What ya need?
Ah crap. I guess I own a stupid zj now.
For $400 it was impossible to pass up. Has mild damage to the driver fender and a small dent in both driver doors, but other than a little rust on the tailgate, the body and underside is amazingly clean. Kid said the "flywheel was broke" and the starter wouldn't engage and the gauges weren't working...wiggled the grounds and threw a fresh battery on and it fired right up and runs perfectly. Gauges are intermittent, it has a loose ground somewhere because the locks click every time the gauges come back to life. Need a lot of little things, but overall it's really solid. Now I need to decide if I want to fix it up and flip it or keep it. For $400 if I keep it, I think it will be getting built a little. 4.0, 242 case and 160k miles. Engine is really quiet and trans seems to shift perfectly...Anyone have a parts zj? I could use some things Ah crap. I guess I own a stupid zj now. For $400 it was impossible to pass up. Has mild damage to the driver fender and a small dent in both driver doors, but other than a little rust on the tailgate, the body and underside is amazingly clean. Kid said the "flywheel was broke" and the starter wouldn't engage and the gauges weren't working...wiggled the grounds and threw a fresh battery on and it fired right up and runs perfectly. Gauges are intermittent, it has a loose ground somewhere because the locks click every time the gauges come back to life. Need a lot of little things, but overall it's really solid. Now I need to decide if I want to fix it up and flip it or keep it. For $400 if I keep it, I think it will be getting built a little. 4.0, 242 case and 160k miles. Engine is really quiet and trans seems to shift perfectly...Anyone have a parts zj? I could use some things Ah crap. I guess I own a stupid zj now. For $400 it was impossible to pass up. Has mild damage to the driver fender and a small dent in both driver doors, but other than a little rust on the tailgate, the body and underside is amazingly clean. Kid said the "flywheel was broke" and the starter wouldn't engage and the gauges weren't working...wiggled the grounds and threw a fresh battery on and it fired right up and runs perfectly. Gauges are intermittent, it has a loose ground somewhere because the locks click every time the gauges come back to life. Need a lot of little things, but overall it's really solid. Now I need to decide if I want to fix it up and flip it or keep it. For $400 if I keep it, I think it will be getting built a little. 4.0, 242 case and 160k miles. Engine is really quiet and trans seems to shift perfectly... Anyone have a parts zj? I could use some things Ah crap. I guess I own a stupid zj now. For $400 it was impossible to pass up. Has mild damage to the driver fender and a small dent in both driver doors, but other than a little rust on the tailgate, the body and underside is amazingly clean. Kid said the "flywheel was broke" and the starter wouldn't engage and the gauges weren't working...wiggled the grounds and threw a fresh battery on and it fired right up and runs perfectly. Gauges are intermittent, it has a loose ground somewhere because the locks click every time the gauges come back to life. Need a lot of little things, but overall it's really solid. Now I need to decide if I want to fix it up and flip it or keep it. For $400 if I keep it, I think it will be getting built a little. 4.0, 242 case and 160k miles. Engine is really quiet and trans seems to shift perfectly... Anyone have a parts zj? I could use some things Ah crap. I guess I own a stupid zj now. For $400 it was impossible to pass up. Has mild damage to the driver fender and a small dent in both driver doors, but other than a little rust on the tailgate, the body and underside is amazingly clean. Kid said the "flywheel was broke" and the starter wouldn't engage and the gauges weren't working...wiggled the grounds and threw a fresh battery on and it fired right up and runs perfectly. Gauges are intermittent, it has a loose ground somewhere because the locks click every time the gauges come back to life. Need a lot of little things, but overall it's really solid. Now I need to decide if I want to fix it up and flip it or keep it. For $400 if I keep it, I think it will be getting built a little. 4.0, 242 case and 160k miles. Engine is really quiet and trans seems to shift perfectly... Anyone have a parts zj? I could use some things Ah crap. I guess I own a stupid zj now. For $400 it was impossible to pass up. Has mild damage to the driver fender and a small dent in both driver doors, but other than a little rust on the tailgate, the body and underside is amazingly clean. Kid said the "flywheel was broke" and the starter wouldn't engage and the gauges weren't working...wiggled the grounds and threw a fresh battery on and it fired right up and runs perfectly. Gauges are intermittent, it has a loose ground somewhere because the locks click every time the gauges come back to life. Need a lot of little things, but overall it's really solid. Now I need to decide if I want to fix it up and flip it or keep it. For $400 if I keep it, I think it will be getting built a little. 4.0, 242 case and 160k miles. Engine is really quiet and trans seems to shift perfectly... Anyone have a parts zj? I could use some things Ah crap. I guess I own a stupid zj now. For $400 it was impossible to pass up. Has mild damage to the driver fender and a small dent in both driver doors, but other than a little rust on the tailgate, the body and underside is amazingly clean. Kid said the "flywheel was broke" and the starter wouldn't engage and the gauges weren't working...wiggled the grounds and threw a fresh battery on and it fired right up and runs perfectly. Gauges are intermittent, it has a loose ground somewhere because the locks click every time the gauges come back to life. Need a lot of little things, but overall it's really solid. Now I need to decide if I want to fix it up and flip it or keep it. For $400 if I keep it, I think it will be getting built a little. 4.0, 242 case and 160k miles. Engine is really quiet and trans seems to shift perfectly... Anyone have a parts zj? I could use some things Ah crap. I guess I own a stupid zj now. For $400 it was impossible to pass up. Has mild damage to the driver fender and a small dent in both driver doors, but other than a little rust on the tailgate, the body and underside is amazingly clean. Kid said the "flywheel was broke" and the starter wouldn't engage and the gauges weren't working...wiggled the grounds and threw a fresh battery on and it fired right up and runs perfectly. Gauges are intermittent, it has a loose ground somewhere because the locks click every time the gauges come back to life. Need a lot of little things, but overall it's really solid. Now I need to decide if I want to fix it up and flip it or keep it. For $400 if I keep it, I think it will be getting built a little. 4.0, 242 case and 160k miles. Engine is really quiet and trans seems to shift perfectly... Anyone have a parts zj? I could use some things
Sent from my XT1650 using Tapatalk
I own a zj now. Half of my brain stopped working instantly. No more long posts.
I also have the urge to grow a mohawk
