wrecked
- Longview Washington
So I'm throwing out my Ford arm's and building up a 3-link. I need some analysis though. I don't really know what I'm doing as far as preventing anti-squat and all that.
So heres what I came up with...
*orange= coils
*red= axle/tierod mount
*blue= cross member(already in place on the jeep)
*grey= frame and links
-The upper link will be mounted to the lower link. I wanted to get some help quick and I figured that you guys are smart enough to figure out that it would be attached.
-Everything should be to scale, except tubing diameters.
-The red block on the left between the coil and the upper link is where my tie rod mounts currently. I put the upper link so that my tie rod wont hit when at full compression or ride hieght, I shouldn't have to worry about it hitting at droop due to the tie rod moving up and out of the way.
-The link length is 44.8 inches. Seems like that may be a little bit long, but I'm going to use the cross member(1/4" thick, braces the frame) that I already have on my heep and it fits that length perfect, plus I want alot of articulation as I 90% if my offroad time on rocks.
-I'm on fullwidths and the link placement in the design is based around that. I also curved the links to mimit the chance of the links hitting the frame during up travel and allow for my to turn a 37" tire to full lock.
Things that I'm looking for are:
1) Is the design is good.
2) What side do I need the upper link on to prevent the axle rotating. I think that I recall that it matters as the drive shaft turns one direction and if your link is on the wrong side it tries to lift that side or something of the sort.
3) Any predictions as to road manners.
Something along those lines.
For the joints
At the frame should I run...
Option A
Uniball
Option B
Spherical Flex Joint
Option C
Jimmy Joint
Option D
The typical rod end
For mounting all 3 links to the axle I will be using bushings. Mainly because using a flexible joint at both ends I believe wiall allow too much play in the axle and it really not nessacary.
Please all that can, chime in with your two cents. I've got to get this project done and driving again in a month and as many problem that can be elimintated as possible before hand would be awesome.
Thanks in advance and sorry for misspellings and bad grammer, its late.
-Kevin
*orange= coils
For the joints
Option A
Uniball
Option B
Option C
Jimmy Joint
Option D
The typical rod end
-Kevin
