How to remove u-joint cap?
01sesedan
Sunny Florida
Trying to remove u-joint and have this problem.
Hope someone could help out. I'm stuck here. How do you guys remove this cap? It's on very tight...
Here's how the other side looks.
Gotcha. With a vise and a small socket backwards on the exposed part of the joint, I might be able to push it through? I would need a socket large enough for the metal cap to go in, right?
Will locate a vise.. Thanks..
Buy, borrow or rent a Ball Joint Press. Most parts stores will loan you a tool if you buy their parts. It will make the job much faster and will reduce the amount of cussing and sockets flying across the garage.
Gonna get the press, it's $100 at autozone. You get the money back when returned.
Thanks for the input. Was able to get it out. Now I have to find a ride to AZ and get the press...
