We've been using the spindle/bearing setup for years, but with more people wanting to throw larger tires on the back...along with a gas can mount, hi-lift mount...
Not feeling real cozy about that setup, would much rather see something in double shear if possible. My first thought was to weld in solid chunk of cold rolled steel, 1.25-1.5", drill and tap the top for a support. Use a delrin sleeve with thrust bearings top and bottom for longevity.
Problem is there's just not a lot of space on top of a bumper for much. It'd be a lot easier to put the hinge on the face, but then it gets into a matter of looks and most people don't want it there.
Key points to a hinge design...
Needs to stupid strong.
Needs to be fairly simple to keep costs low.
