Oh my gosh! Had to let you guys know about my latest lighting upgrade.
I've been running the IPF headlights and the 4x41 bulbs (80w low/60w high) for some time now. Light output improvement is
DRAMATIC over stock. Here's a pic from my website showing the factory light on the pass side and new IPF light on the drivers side. This was with the factory wiring harness.
Low beams:
High beams:
I've run the IPF lights with the wiring harness before, (on my TJ) but I hadn't added the harness later to the existing setup.
I added the wiring harness and a set of the IPF 80/110 bulbs yesterday.
HOLY SMOKES!!!:gee::looney::yelclap::clap::worship:
As one who should've known better, I cannot believe the difference these mods made! The new bulbs still have the same 80watt low beam, but the light output is hugely improved. The harness made an enormous difference. Dramatically cleaner, brighter light.
I can't even explain the difference between the 60watt and 110 watt high beams. Awesome... WAY more light than before. Much better coverage of the road sides and much longer distance too. Wish I'd done this a long time ago!
If anyone out there is running IPF headlights and 4x41 or Fat Boy bulbs (or other headlights) and you're wondering if a wiring harness is a worthwhile upgrade, let me encourage you to GET THAT!
If you wanna go all out, opt for the higher wattage bulbs too. You won't be sorry...:cheers:
