Mgtawt
- Riverside, ca
who makes the headlight harness upgrade kit for led light ?
thanksMost any universal H-4 headlight harnesses will work. I bought one on Amazon.
Hella makes a good one, so does Susquehanna Motorsports.
do you have any issues with switching low high beams ?Most any universal H-4 headlight harnesses will work. I bought one on Amazon.
I forgot to add that the Amazon chineasium harness that I used as a bandaid had to be reworked because the relay sockets weren't wired correctly.....and the supplied relays only lasted about a month.Are you able to switch from low beam to high beam and back to low beam? That’s the problem I’m having but then again I bought an Amazon cheap harness from true mods.
I put a new harness but i cant switch between high beam back to low beam unless i turn the lights off then back on
Any one have a fix
