njjeepthing
- Manahawkin, NJ
For 93-06 Jeep® Cherokee XJ, Grand Cherokee ZJ, Wrangler TJ & Unlimited
Beef up your ride with Rugged Ridge steering components. This is a bolt-on solution for preventing bent tie rods from wheeling with larger tires. The tubes are 1-1/4 inch ID steel that is cold rolled, pierced, and drawn through dies to produce a 1/4 in. wall thickness. This is true DOM tubing with NO seams OR welds to fail. Heavy duty 7/8 inch rod ends feature standard tapered ends to fit stock knuckle applications. You get one ton strength without any modifications to your steering knuckles. Will not work with Right Hand Drive vehicles. Will not work with Factory Rubicon Wheels.
This is pretty much NEW, was installed and it hits my factory wheels, so it's of no use to me right now.
Retails at Quadratec for $229.00
I'll sell it for $150.
