- Hammertown, USA
what are you using to prime the motor once it's all together?
The same thing I have used for the last three.
https://www.naxja.org/forum/showpost.php?p=246120651&postcount=1381
So...what the running total on this stroker build?
:laugh3:
Just looked up the price of that oil pan...
****in OUCH!
Thankfully Russ is a Moroso dealer, so the hit wasn't as bad as you think.
Which is good because I needed that savings to buy a fancy red valve cover from Crown and 3 stud kits so I can stud both the pan and valve cover. Because gratuitous.
****in OUCH!
More than I budgeted. Less than you'd think. We re-used a lot of parts from 4643 and Russ gives me the buddy deal on a lot of stuff. Out of pocket I'll be an average stroker build in cash. If you subtract the head and the gratuitous bling stuff, under $1500.
