Your new ECU will need some time for adaptive learning of your engine's sensor outputs, so I'm sure the idle will settle down once you've accumulated a few miles.
Tip: Take a can of starter fluid and spray down any area that might be leaking vacuum while the engine is idling. If your idle spikes when you spray an area you've found your leak.
