I'm running 5x? steelies. As you can see in my first picture, the clearance looks to be a little less than what I have on the bottom of the knuckle.
Judging from your picture, it looks as though your knuckle is higher than mine to begin with. Mine sits about even with my u-joint, and yours looks like it's a little higher. Could be the angle of the shot though...
EDIT: I will have the Jeep on the lift this weekend, and am planning on doing axle seals and bearings anyway, so it will be a good time to figure out exactly what I have for rim size and backspacing.
I bought an insert through paypal on the first of the month. Didn't hear from them and emailed em a few days ago. Got no response, but I did get the insert in the mail yesterday.
I know it's been a while, but I still have my set, unused, I'd let them go if anyone is interested. I think they are $18 each new, I'd sell them for $15 each and I will even ship them for you.
I just installed a new insert a couple days back and decided to check their website for install instructions. My thinking was that you just hammer it in and your good to go but I figured I should double check. I'm glad I did because their instructions state that you need to weld the insert in. I don't have a welder and did not do that yet. For those of you that did go with these inserts; did you weld them in? If not, any issues?
i ran mine without being welded for a little bit, had no issues. dont see why there would be, as long as the hole you drilled isnt extremely wallowed out and the insert is a snug fit. but i did eventually have a few tacks put on. and i would HIGHLY recommend ditching the nut that came with the inserts and using a standard castle nut and cotter pin. that or loctite the provided nut on the TRE with some blue loctite.
I didn't use the provided nut either, I went with the castle nut and pin. But after I installed it I found a serious problem. The castle nut is just about the same diameter as the insert. That means that there isn't much keeping the insert from popping out the top. I realized that as I cranked the nut tight it was only pushing against the insert and nothing else.I decided to add a washer between the steering knuckle and castle nut to ensure the insert couldn't work it's way up and out. I will probably add a few tack welds to the top of the insert eventually to keep it from spinning once I find someone with a welder.
It's about the same size, which is why there is a serious problem. the outer points of the nut go out to the edge of the insert but don't go out onto the knuckle. The provided nut has an attached flange that widens it's base to almost an inch but a standard castle nut does not have that. I hope the addition of a washer does not cause some unforseen issue. I can't see why it would.
The provided nut has distorted threads, so I highly doubt it'll come off any time soon. I had a hard time even getting mine fully tight with an impact because the TRE stud kept spinning.
