XGarfX
- North Jersey
6.0s have their issues just as most newer emission controlled diesels do, fact is though if you want it to be reliable it needs to be stripped of the egr system and it needs head studs done.
6 liters have a B50 rating of 300k miles from International, if the egr cooler/valve fails you might as well just bypass it. If you plan on hauling heavy loads and hogging it around like a madman you CAN blow head gaskets, there are guys out there running heavily worked 6 liters with 400k plus on them with very little problems and theres also guys out there doing head gaskets at 80k miles.
If you want the truck to last long indefinitely "bullet proof" the 6 liter. The engine makes tremendous amounts of power and can out run most any 7.3s with a trailer. I wouldn't pass a non beat to piss 7.3 though, reliable and age tested, plus their much more simple.
