mikecooper
- NRH, TX
I have a full width ford 9" with a strange spool(31 spline big bearing) and 5.13 gears that has new bearings on the shafts(never run). Its currently setup for a sprung over yj. It has drums but needs all brake shoes and hardware. $650
I also have a full width d44 front from a 75.5 f100. It has the weld on mounts that can be cut off but the down side is, its drum brake. I would be easy to convert with parts mike true flat tops and junkyard chevy small bearing spindles ford rotors and gm or ford calipers. It come complete from hub to hub with all the steering attached. $350
For the 44 i have nib Yukon reverse spiral 5.13's and a series 4 carrier that is welded. $180 for the gears and carrier
Firm on all prices. Loacted in North Richland Hills Texas 76180. I am willing to deliver to most places in Texas and Oklahoma.
Call for more info if needed (940)210-1056 Chris
