4WDXPRT
- Spokane, WA
An extremely well built XJ that looks great and dominates any trail you're comfortable tackling. Currently selling as I'm going to buy a 04 Dodge Cummins 600 and need more room for growing family and big dog.
I also have a clean 1999 XJ for sale as well. TAKE NOTE: I will be driving this out to California for the July 4th Weekend...Dana Point area. So if you're serious and in California I can deliver it free of charge.
I have mounted 35" MT/Rs from my other Cherokee to show that it will run these as is...it comes with 5 33x12.50R15 BFG A/T KOs and is dialed in for flex with this size tire.
1989 Jeep Cherokee 155k+ miles on body White/Silver
30,000 miles on new 242cid 4.0L MPFI engine by Western Engine
Interior - Good
Nice Carpet
Added rear shoulder belts
Alpine CD Deck, Pioneer Amp, 4 6x9s
Cobra CB
Factory cup holder
Cargo liner
Body – Good
Minor body dings from off-roading/few scratches but looks damn good for 14 years old.
Tastfully trimmed fenders
CJ Hood Vents
Firestick CB antenna
Protofab pre-runner (non-winch) front bumper w/ Hella 500 fog lights
Tomken rear bumper and tire carrier – customized to hold hi-lift jack (hi-lift included)
All JP Boulder Bars Rocker Panel protection
Factory gas tank skid plate
Tomken transmission skid plate
Suspension - 7.5” lift (multi-vendor)
Rubicon Express ZJ 4.5” coils
2” RE spacers
Rubicon Express HD drop down brackets + Braces
Tomken control arms w/ johnny joint
New upper contral arm axle mount bushings (October 2003)
Tomken/RE leaf packs
1” block
1.5” lift shackles
Rancho RS9000 shocks
JKS bar pin eliminators for front and rear
JKS shock conversions for the front shocks
JKS quicker disconnects
Poly Sway bar bushings
Rubicon Express Heim track bar
Rusty’s Off-Road steering box brace
Heavy Duty tie rod and Drag Link modified for extra strength
Drivetrain –
30k mile 4.0L enigine. Runs Excellent No Leaks
M.O.R.E. Bomb Proof motor mounts
NEW Cat Back Rock Crawler Exhaust 2.5” Custom Routed Design
Open cooling system conversion w/ flow kooler water pump
1996 newer style electric cooling fan (more blades/better air flow)
Accel Super Coil and 8mm plug wires
HO style oil filter housing
2 gauge battery cables
160 amp altenator
Open element S&B Racing air filter (5” power stack)
ARB Air Compressor with tire inflation kit
Front High Pinion Dana 30 4.56 gears, ARB, stock shafts with spares, Summit Off-Road Diff guard
Currie Enterpries High Pinion 9” rear 4.56 gears, ARB, 1999 Ford Explorer disk brakes
Modified proportioning valve for better flow to Currie Rear Disc Brakes
Custom Englewood Drive Shafts
NP 231 T-case with J&B Conversions SYE (32-Spline Output Shaft!)
AW4 auto/mannual tranny (Full control over 1-2 Shift Pattern, Torque Converter and Valve Body)
NEW 4x4 Posi-Lok Cable operated front axle fork actuator; 2WD Low Range + Full In-cab control; Upgraded Cast Iron Shift Fork to replace weak OEM aluminum version http://www.4x4posi-lok.com/
Tires/Wheels-
5 33x12.50 BFG Kos siped
5 15x8 Eagle type 55 3.75” bs wheels
MISC-
Have added aftermarket keyless entry and new relays, all locks work with force even in very cold weather.
Tinted windows legal on front windows 5% on the rest
Replaced opening wing windows with stationary windows for quieter ride.
See pictures at: http://www.cherokee4wd.com
$9500
If interested call Randy Harris @ 303.349.1294
Interior - Good
Nice Carpet
Cobra CB
Factory cup holder
Cargo liner
Body – Good
CJ Hood Vents
2” RE spacers
1” block
1.5” lift shackles
Drivetrain –
160 amp altenator
Tires/Wheels-
MISC-
$9500
