asp
- Westport, MA
i would think that because you have already made 1 set, the rest would follow with minimal work...
The rigid ones wouldn't be too hard to make right now. Its just that the models for the back flares are being redone and that part takes lots of time.i would think that because you have already made 1 set, the rest would follow with minimal work...
Yeah, I agree, the BWs are too wide. By the way, thanks for the compliment.I noticed that the results of the poll are favoring neither flare. I just don't understand that. I love having options. I would vote for you making both ridgid and flexible if that was an option. I would love to have some of those like in your photo. I personally think BW's look like crap unless you have really wide tires.
Thanks for the post.Your flares look great, but it's so cheap and relatively simple to make them out of TJ flares I'm really surprised Bushwacker and Rusty's sell enough to warrant production. I'd assume you could beat Bushwacker's price, but could you do it and still be profitable?
Good luck either way, it's always cool to see innovation at work.
u can use tj flairs on a xj?
Yeah, if you're going real big they might not work. This setup is 33x12.5s with about 6" of lift and the tires will fully stuff without a problem.I'd be interested if they were as wide as the BW flares. I think they look great. If they're only a couple inches wider than stock I would have to pass, as they wouldn't clear the tires/rims I'm choosing.
Doug
These work well for me and I just thought some other people might be interested.
Doug
No problem, I fully agree that different approaches are going to work better for different people or situations. There are so many ways to build jeeps and each way can be perfect for the guy building it..............Don't get me wrong, im not trying to turn this into a yours vs BW discussion................What wheel dimensions do you run to make it fit correctly under your flares ?
Nice jeep Hammered. How much lift are you running and what size tire?I say forget either of those and go OEM style which is hard but has plenty of give. Wont break or Flop.
