Cheropair
- Kansas City
OK, so maybe I'm wwaayy off the mark on this one---
Was just helping my Uncle change a tire on his tractor, thing weighed a lot more than it should have. He explained that it was full of a water/chloride mix. Made me think - on a trail only rig, would putting water in the tires add enough weight to seriously affect the center of gravity? A 33 or 35x12.50 would hold quite a bit of water, maybe a 150#? Right at the bottom, seems like a good idea. Maybe leave a little room at the top for air, so you can adjust the pressure.
Wouldn't be of much use for mud, weight is usually a bad thing. Was really thinking about side hills with good traction (rock crawling). High speeds don't seem like a good idea, something about trying to brake with all of the rotational mass - or would the water just spin around inside the tire, not affecting braking?
Last thought, after draining for the trip home, there would still be some water in the tire - would this work like the BB/golf ball/Equal/Centramatic balancing trick?
Whew, too much work, not enough sleep - bone head thoughts and ramblings........ Goodnight, my friends!
