Rear Axle Breather Hose Extension
Reasoning:
Axles need to breath. Axles have gear oil, and air in the differential and housing. Axles can heat up under load. Air expands and contracts depending on temperature. When axles get hot, gases need to escape. When it cools, air needs to breath back in. Axles have seals. These seals would be sucked in or blown out due to pressure of interior axle gases. So there is a breather on the top of the axle housing that allows air flow. When the differential is hot, air expands and the breather is breathing gases out. Now when the hot axle hits water it can cool rapidly, causing the axle to breath in.
Now if both the breather and axles air under water, it may suck in water through the breather and axle seals. So I wan to extend my rear axle breather to a much higher elevation to avoid this.
I run into a lot of water crossings on trails, some of them deep. While I am not trying to recreate "The Yellow Submarine", or make a habit of fording rivers, sometimes water happens. Sometimes it gets a lot higher on the way back then from when you first cross it as well. One trail I have had water up to the bottom of my headlights. Granted that was with a steady bow wave while crossing, but you get the point.
Now since I have recently re-geared my axles last fall and changed the diff fluid a few times while breaking in the gears, I don't feel like doing it again for awhile. Nor do I feel like blowing out my axle seals, or cleaning out mud and water from my diff.
So I decided to look into extending my rear axle breather hose.
I read a few write ups, and decided I liked the simple idea of the breather hose behind my tail light for now. May change it later.
Side Note:
This also got me thinking about later possibly using a similar set up for a gravity fed water supply, and some sort of water spigot. Mount water high (roof), have spigot lower on outside of vehicle (rear bumper or maybe even the hatch) with easy access. Something to consider for a later project.
Supplies:
3/16 inner - 5/16 outer clear tubing from Fogg's Hardware .69 cents a foot.
3/16 elbow coupling $1.29
Hose clamp
Drill
Quick and easy mod that provides some assurance.
Remove Drivers Side Tail Light and Drill Hole
Feed Hose through Hole
Remove drivers side rear quarter interior Trim, Pull back carpet, drill Hole in Rubber Plug in Cargo area, and feed hose through
Attach to Axle, make sure to have slack for flex, route it so it does not get snagged or pinched.
Attach fitting and secure hose
______________
Follow our adventures at Nomad Expeditions
