So that was you at Deer Valley? I've been trying to place your screen name with the face. I've been eyeing your Boatside thread. That's quite the project!
I would make a sort of half moon shaped piece that follows the countour of the wheelwell and goes down to the floor to distribute any force exerted on the wheel well to the whole structure not just a small patch.Personally I would box in the fender well mount, on both sides. It would distribute the load over the wheel well area better and not run the risk of tearing the sheet metal. Even with the backing plate, the vertical bolts could tear and elongate if push with force from above.
Here's a quick view of my idea.
When I first did the rocker replacements, I just used silicone to seal/secure the bottom of the fender to the rocker, but as you can guess, that didn't work out so well. While doing the cage, I welded a small tab to the rocker that I could bolt the bottom of the fender to. Much more secure. If that is what you are asking pictures of maybe I can get some when I finish off the front. I'll be pulling the fenders off for that so that would be the time.Do you have a close up pic of the A-pillar, fender and rocker? Did you do anything to mount the bottom of the fender to anything?
Eric and others who have Hybrid cages like these, I've noticed the majority of you guys don't bother installing A-pillar down bars and upper and lower windshield bars in the interior. Are you confident that the exterior A-pillar bars will keep the roof and windshield from pancaking in a flop or full roll?
I've seen them from $1500 to $3000, most were the latter.
What difference does a internal vs external A pillar tube make?Eric and others who have Hybrid cages like these, I've noticed the majority of you guys don't bother installing A-pillar down bars and upper and lower windshield bars in the interior. Are you confident that the exterior A-pillar bars will keep the roof and windshield from pancaking in a flop or full roll?
That better including labor at a shop. That, or tube is fawking expensive where you live.I've seen them from $1500 to $3000, most were the latter.
Mosephus,Yes those are shop prices, it will probably be under 1k if you don't have to buy tools and you know what your doing. Sorry didn't read the question right
To answer the first question....To me mostly a longer distance or radius from it's supporting tube than the internal option. The feet are farther forward on the external cage. Please refer to my scientific drawing.
I'm just wanting to know if the external tube is enough by it self. Mostly for safety, but for the XJ's tin too.
