Alright, time to re-hash this old subject once again. I lifted my jeep 4 inches recently, the rear springs (rustys 4 inch full packs) give me right at 4 7/8 inches. I was having some driveline vibe issues and now have 4* shims in the back and a 1 inch t-case drop. When I put a magnetic angle finder on the t-case and the pinion my angles are exact, meaning they are perfectly parallel to each other (angle reading on finder is 85.5* on pinion and 85.5* on t-case). Driving this thing down the freeway gets me some vibes at 35-45 then they go away, then at 60 theres a small vibe that returns. Its not a bad vibe, just a low underlying, buzz of a vibe. Also around 45mph when i get off the gas and coast theres a small roar comming from the rear end which suggests axle wrap. I have removed my rear swaybar and have a custom cut driveshaft under it. My problem is Ive chased this vibe down forever and am jut tapped dry of ideas. The only thing I can think of would be the driveshaft. When the shop cut it, they cut it a little too short and there is about 1 5/8 inch of spline engagement. The driveshaft IS balanced and is the same one I was using before the lift(no vibes, but less than ideal engagement). Other than the driveshaft and u joints(rear is new, front isnt, neither have ANY play), the only thing i can think of is axle wrap which was mentioned to me once before, but it doesnt seem like the cause considering I dont romp on the gas at all during acceleration. Im seriously considering getting a SYE and CV driveshaft in a couple weeks when money permits, but would like to solve this problem without shelling out 600 bucks.Anyone with a clearer brain and expierence chasing this bug feel free to chime in with yer opinion. And sorry its such a long read.
Thanks
Mike
Disclaimer: My skill with dealing with lifts is extremely minimum, and I dont practice K.I.S.S. very often
Thanks
Mike
