jeepingben
- Maine
Recently I became worried about a deer (or even a turkey) taking out my radiator and immobilizing me on a long trip coming up.
I found a great deal on a clearance warn trans4mer grill-guard and it seems like people generally regard this as a real one and not a pretty one or damage-multiplier.
The brackets for this are thick and the kit instructs me to drill out the bolt holes for the included grade-5 1/2" bolts, but they fail to go as far back on the frame-rails as the factory-option 6000lb winch mount. A few big bolts vs lots of small bolts seems like uni-body 101 stuff. I am keeping my outer tow-hook brackets so the grill-guard will tie into the bolts further back as well.
I know people use this system for winching so it must be good enough for that and the uprights seem strong enough, but why leave out that bolt hole to save a few square inches of plate?
The included cross tubes are 14/16 ga steel and attach using a single bolt threaded through some steel on each side.
Is this steel enough? I know the bolts aren't. My plan now is either to bolt and weld these tubes, or order some thicker tube and add multiple bolt holes and/or weld them.
Has anyone had experience with this system. Did it bend when you didn't expect it too? Did it take a lot of abuse?
I want some strength in return for the weight/length I am adding, but that DOM tubing is expensive and I'll only add it if it is needed.
Thanks
Thanks
