SolarBell
- Wheat Ridge, CO
So I'm trying to find the source of a noise the sounds kinda like a bag of rocks rolling around somewhere. Problem is that it doesn't do it all the time. Popped my front diff cover and the fluid that came out was full of little sparklies, but no huge chunks. The magnet inside my diff cover didn't catch much either. But I'm not sure if my ring and pinion look right on their wear pattern. What do you think?
These were installed by you-know-who about 2 years ago.
While it's apart I'm checking my axle shaft u-joints and greasing everything, then checking my flex plate and bolts.
Anything you see wrong or anything else I should check?
