montanaman
- Western Montana
1991 XJ with D30 front diff.
I've got my entire front end torn apart for steering & BJ replacement, and my diff opened up to drain the oil and replace the leaking pinion seal (breather was blocked).
I'm going to replace the inner axle oil seals while it's opened up. Can someone tell me the Dana/Spicer part number for those seals? And a pic of the seal if possible?
The reason I'm not sure is because Rock auto lists spicer 46470 as not working on the right side of disconnect models. I don't have the disconnects, but I'm thinking ... wouldn't the inner oil seal be the same on the disconnect models? I know that the outer tube seals are different with the disco models, but I thought the inner oil seals were the same. I'm wondering if maybe this part is the axle tube seal. Anyway, here is a pic of what I'm talking about. Is that the inner oil seal or the outer tube seal?
http://www.rockauto.com/en/moreinfo.php?pk=4900455&cc=1180055&jsn=492
Thanks for your help.
