Abugarcia
- Minneapolis, MN
I just bought a XJ and I really need some control arms. I am leaning towards builting my own. I am planning to use these http://www.crawltech.com/catalog/images/2.5-lrg.jpg on the end of some 1-1/8 DOM tubing with 1/4" wall. I have a few questions about this setup: Since I have access to a lathe I planned to drill out the tubing to 11/16" on each end and tap the ends with a 3/4-16 thread and screw in the JJ's and jam nut. I don't think I have seen anyone do something like this without useing tubing inserts. Is there a good reason not to? Also when using such a joint do I need to use anything the joint doesn't come with such as a misalignment washer or something to keep the bushings centered, or can I simply put the joint in the mount and run the bolt threw it? Any input is much appreciated.
