Well, a couple of hours after everyone left for the Rubicon, I actually finished the axle project (except for some painting). I even had it aligned. It seems to drive fine. I tested it slowly and hit as many bumps as possible hopeing for the best and expecting the worst but it seemed fine. I even worked my way up to the freeway and hit 75 (I know, too fast for a lifted XJ
) and it was fine.
I do agree with BrettM that it is a little tall. I think the rear leafs are too much for my taste and I would like to get a 6" leaf pack that might not ride as stiff as my 8" Alcans. The only reason I put the 3/4" spacer in the front coils was to TRY to make it close to level with the rear. So with a 6" leaf pack and a strait 8" coil I think I will be happy. I never thought I would say this but I need to lower my xj 2" in the rear and 3/4" in the front.
I took it to my wife's office today to flex it out with a fork lift to make sure nothing touched and everything was okay. After checking it out I get about 30" of lift on one tire with the three others on the ground. (
Is this about what others get?) I think I had one to two more inches of height (31 - 32") with the 7" Tera Flex front end with a 2.5" ProComp leaf pack, 2" of blocks and 1" lift shackle. I think it is the lack of flex from my leaf pack that causes the loss in articulation. The only real thing I had to do was re-locate and zip tie my axle breather and ARB air line.
Here are some pics. I know the steering stabilizer' set up is cheesy (and potentially defeats the purpose of high steer) but it is temporary until I get the final position of the drag link (a future new stock XJ pitman arm) and track bar (I will lower it when I get the new pitman arm). I am hoping to have a better approach with better clearance with the 'final' set up for the steering stabilizer.
Here are my results from my alignment. I would love someone (BrettM, Crash, Goat, Jes, PaulS, etc.) to look at these and let me know if I should change anything. The guy who did the alignment was really happy with the results but all I do is look at the piece of paper and scratch my nuts.
IF anyone is curious about my current angles (Crash, per your comment earlier) here is a pic with some lines to show the current set up.
I think it looks pretty good and I don't get any noticable bump steer.
-Cracker
