I have a 2001 XJ, 4.0, Auto. It has 43K miles on it. Ran fine yesterday, parked it overnight, today it won't start. Turns over strong, but no go.
Fuel pressure is 46.5 psi. All fuses are good. Swapped around some of the relays and made no difference. No codes stored. Have not found a test procedure for the coil packs, but I'm assuming I'm not getting spark.
All signs point to a bad CPS but everything I read suggests it should be good to 100K plus. I haven't been able to locate the connector for it so haven't tested it yet.
So, has anyone else run into a CPS that failed at such relatively low miles? Does age matter more than miles?
