Beached Bones
- Winnipeg
HI, I'll write this long to try to give as much details as possible. I am a fair backyard mechanic but have never gone deep into the engine before.
My 92 XJ 4.0 auto (engine rebuilt 40,000 km ago by a mechanic), slowly and progressively started running real rough, lacking power, and would stall when coming to a stop. It has had poor mileage (9-12 mpg) It would surge at highway speed and the idle was inconsistant. Also my valvetrain noise is strongly noticeable and has been getting worse. Not long ago I changed my 02 sensor. Following some information posted here, I changed my Cap, Rotor, plugs and wires, no change, my Crankshaft sensor was replaced next and it was much better, my idle speed is right on, and I don't stall anymore. It still runs very rough, and "seems" to have excess water coming out of the exhaust (no catalytic converter) I don't think I smell coolant in the exhaust but am not 100% on that. Also I don't think I am loosing coolant, if so very slowly, with no visible external leaks. There is no oil in the coolant/antifreeze, and there is no coolant in the engine oil (no milkshake like or brown oil). I have checked that there is spark with a inductive spark tester. Fuel also seems fine but I havn't really tested the presure or anything.
After all that I was guessing that maybe my headgasket might be blown between a cylinder and the water jacket, or that I've got some problems with my valvetrain. I don't think the piston rings are the problem as they were replaced with the engine rebuild. So I went today a bought a pressure tester. the readings I got were as follows:
#1 130
#2 145
#3 140
#4 0 both dry and wet test
#5 140
#6 0 - 60, initially went up to 60 and held it, then stuck at 0, maybe just twitching a bit on the second and third try. The wet test gave me a 0 reading as well.
This was done pulling only 1 spark plug at a time.
My understanding of this means that I probably?? have something wrong with the valves?
My big question is do you guys think that's the problem too? If so is there any other tests I could do? And lastly if it is a problem with the valves how do I go about fixing them? Is there any writeups out there?
Thanks in Advance
#1 130
#2 145
#3 140
#5 140
Thanks in Advance
