So no photos with this update, but last night we got the new condenser installed. I ordered an 11x24" parallel flow condenser and we're going to run the vacuum on it and verify that we've not introduced any leaks before giving it a charge.
Meanwhile the new rear bumper is almost done. I picked up a used Nates 4x4 rear bumper with a 2" hitch and d-ring mounts so now I finally have a hitch for the MJ without having to deal with building my own, using some generic, or hunting down an elusive U-Haul unit.
Speedo and cable were replaced and man, you really need to grease the snot out of the cable for it to run smoothly. Took me two gears and 2 cables to get it right and the Speedo is still a little jumpy.
New floormats are in (thank you Keith!) and they look pretty sharp. Will be working on the truck tonight, might get the AC wrapped up and maybe, just maybe get the rear bumper painted black. It's primer red right now.
Bob and I are still unloading from NACFest and it's taking time to get the garage back into a semblance of order. With tonight, and possibly Monday working on the MJ we might actually get the 8.8 under the truck and the new M.O.R.E spring perches tacked into place for final welds by a local shop.
It'll be cool to get the tires on it since we'll need it to sit on them for proper pinion angles. Of course once I have the angles and pinion to t-case measurements I'll have to order the new SYE and driveshaft.
I've crested 8K in total investment in the truck, and my goal is to see if I can finish it for under 10K. Of course the $80 i just spent on original FSMs are worth it in my book, haha.
Tim
