Ok does anyone know where to find a good flair tool with the button/attachments that I will need. Is there a tool that does all 3 flairs? With good quality.
go to toolsdelivered.com and look under refrigeration tools. then automotive, then tubing tools. you will all what you need for flaring tools. by the way, these are snap ons industrial brands tools. and this site sells them at GREAT prices. i bought my A/C vacume pump and guages through them and they are awsome.
Yes, it is the brass looking thing right under your master cylinder, It will have 2 lines going in and 3 coming out(2 to the front brakes and one to the rear) unless as said above, you have ABS
The MJ is a whole 'nother animal as it will have 3 going in and 3 going out. the extra line going in runs from the load sensing valve in the rear which is nothing more than a variable proportioning valve. I eliminated the load sensing valve on my MJ when I installed the 96 XJ booster/MC/prop valve.
