xjaddiction
NAXJA Member #666
I liked the swaybar disconnect tethers sold by DPG but thought there was some room for improvement. This is what I came up with.
First is an eye bolt with 1/4" machine thread, and two flange nuts. These go in the holes that already exist in the inside front corner of the inner fenders. From there I used a locking ring to secure one end of a rubber strap, and a caribiner to secure the other end. Another option is to use caribiners at both ends but this design gives a little more room. Total for all the hardware needed for both sides was about $12. When you buy the hardware make sure it is the right size to fit over the rubber.
For the rubber strap I used some black tie-down things and cut the oversized end pieces off, then cut the remainder into sections of the desired length, rounded the corners off and drilled 1/4" holes in the ends. Here is a pic showing a couple of 7" pieces, but I eventually ended up using 12" pieces with 11" distance from eye-to-eye.
Here's a pic showing the tension on the final pieces. They are stretchy enough for the caribiner to hook onto the eye hook, but the caribiner can be hard to remove and this tension secures them alright. You could cut them longer so that the caribiner would reach the top, however this way gives your hand more room to work. Also this design leaves enough slack so that you can hold only the swaybar itself (minus the disconnects) by lightly stretching up to the eye-hook.
The distance is also good for when the tethers are hanging loose. They are not so long that they are in the way, but they are long enough that you can hook them around the fender support brackets in the front.
My only real concern is that the rubber may get weathered and brittle, but no way of knowing how bad or how long it will take. I would also like to put grommets in the holes, but I think the rubber is too thick.
Nice trick!! great thread...
