Jeepm@n
- Northern, WI
Advice needed. Ok my 99 has a bad steering knuckle and u-joint on the passenger side. I was going to replace the axle as a whole but after some thought I'd still need to replace the hub bearings and u-joints anyways. So I guess my question is do I need to change the ball joints on the drivers side too being I'm changing the ball joints on the passenger side? I'm changing the steering knuckle, ball joints, hub bearing, and u-joint on the passenger side and was hoping to only change the hub bearing and u-joint on the drivers side.:repair:
Rather have MWC advice than oem tech
