Automatic transmission
I have a new grizzly locker in an 8.8 and it has a ton of play and slams into gear. The shop that installed it called Yukon and they said it is normal for some play. But it is a lot of play and isn’t a small clunk. It’s very harsh and sounds like someone is smacking it with a sledgehammer when I change gears. The gears are tight and the pattern is good. The pinion moves about 120 degrees before the tires start to receive power. Anyone have a grizzly locker to tell me if it’s normal or if mine has excessive play?
