JJacobs
- Fort Collins CO
These headers will only work with 2 wheel drive, they are a homemade full length large collector design and eliminate any chance of sneaking a driveshaft thru. Upper control arm mods are also required. Specs: 1 3/4 to 1 7/8 stepped, 3 1/2 inch collectors. The motor mounts as with the headers will fit any AMC V-8 into an XJ or MJ. They bolt to the stock motor mount pads on the block and use YJ poly leaf bushings, all you need to do is hang tabs off your 'frame' rails and bolt them up.
Gotta have a price.. don't really know.. let's say 300.
