clean4drxj
- CT.
Cowl intake would work good for the NE keeps the filter high n dry and draws cold air only draw back is it makes the cab noisy.
Maybe install some dynamat?
I like your tube work under your front fenders. I have been thinking of doing that myself. Great Build
You could just switch back to a stock pitman arm and get rid of that YJ arm. It will definitely help with drag link angle. Redo your track bar to make it as long as possible and you'll be able to fix your steering problems.
