318SixPack
- East Tennessee
For ages now, if the A/C clutch engages it squeals, drags the engine down pretty bad, and even seems to smoke the belt.
Is there a way to check if the problem is the compressor vs. the clutch?
I have a new Four Seasons clutch and am still within the return window. Seeing if there is a way to diagnose this without swapping the clutch, and still having the same problem.
Will putting a wrench on the nut (nut at the end, not bolt head) and turning work to diagnose? If center hub turns the compressor is fine, if it's shot the shaft won't turn?
Thanks
Thanks
