avnsteve
- South Austin or North San Antone
recently replaced the TV (kickdown) cable, not necessarily related, but now wife and daughter report "its still acting up" I go under the hood, to "listen" it starts fine, idles fine, UNTIL you blip the throttle (by hand at the throttle body) and then the rpms climb over 2k and then casually draw back down to well below normal idle then dies. Have since replaced the IAC controller (valve?) and the throttle position sensor, still does it occassionally, particularly at low rpm, driving or idling, neutral or in gear
originally posted on NA GC A, but there have been no replies, I believe there are enough jeeple here that someone can clue me in
