4x4JeePmaNthINg
- Colorado
I've had a random off and on airbag light for quite some time now. The last time I had this issue I replaced my clockspring with a Dorman cruise control equipped unit, and the light went away.
Currently my horn works and other than just the random airbaglight, there are no other symptoms common with a malfunctioning clockspring.
Now,
Is the DRBIII the only scanning tool that can tell what the problem is with this recurring light?
If so why is this the only tool that can scan the airbag system?
What could this drb tool say when something is found wrong (does it say sensors or wiring is the issue, perhaps a portion of the circuit) ?
Ive traced wires and check the airbag control module ground, I cant find anything awry here.
Ive tried unplugging the seatbelt wiring and nothing changes plugged in or not.
Im up for any ideas you all have on diagnosing this gremlin, if theres anything else I could do.
I appreciate any help
Now,
