Professor_brap
- OHIO
Alright, need some help. Got P0122, p0700.
New clock spring, clean grounds and battery connection, good battery, new good tested tps, runs a drives fine, light just drives me nuts.
Pulled horn fuse, light comes right back on for those codes.
Unplugged clock spring, light comes right back on.
The tps wiring is good, the connectors for the transmission are clean and good. With the solous hooked up I have correct voltage at tps and sensor is working as it should.
Thoughts? Ideas?
Was thinking is might be a dying ecu or tcu but don't wanna spend the money if I'm overlooking something dumb.
PFA
Thoughts? Ideas?
PFA
