CommandoXJ96
- Tucson
RenixPower said:But I think a consensus from Dan (CommandoXJ96) and everyone else who has done it would be to use the 97+ ebrake.
I found that using your own cable and some cable clamps is the best way to connect the E-brake to the old style cables. Just make sure to use the piece that grabs them both (right and left drum cables) from a 97 or newer XJ also.
The light grey console this swap thread was originally based on has now migrated into my XJ from RenixPowers. I was able to get the ebrake in and everything (had to do some floorpan drilling for the 3rd bolt if i remember correctly). I also installed a home made switch panel by using some project boxes from radio shack and a Dremel tool. That took care of the gap in front of the console between it and the Dash board. Don't mind the bolt you see by the driverside seat belt - the console felt a little loose to me and with people throwing backpacks and their body weight across the console i wanted to make sure NOTHING could unseat my new console... A couple backing plates and bolts won't let that happen.
