- MilkyWay Galaxy
No its not dual fuel.
By the way the 2 year old battery went south, and was going bad before, during and after the radiator hose took a leak. We replaced the battery about 2 to 4 days after the radiator leak when I realized it was bad and not something else. The check engine light came on when the radiator hose took a leak. The DTC code after the radiator leak was misfire Cyl 1 & 2, but considering the coolant was, had leaked, I was not surprized to see misfire codes. He said the engine died and the car coasted almost as soon as the check engine light came on the temperature gauge showed it overheating.
From his story it sounds lkie it shut down with in seconmds of the coolant leak. It was a big, fast leak. Can head gasket go that fast?
98XJeep said:you don't have remove the intake to change the plugs, but you do to replace the injectors.........is this car a dual fuel setup? it will have a green leaf badge on the side or trunk......had a ranger 3.0 that had problems with missfire's. it turned out that the sensor that tells the pcm what kind of fuel it was running on wasn't working, it was telling the pcm it was on reg fuel and the customer was running on E-85
