LOCKED UP
- Baton Rouge, LA
Save yourself some time & money. Buy my built rig.
I have recently (within 1 year) gone through the entire rig & replaced ALL fluids, plugs, wires, cap & rotor, front & rear bearings, ball joints, brakes, battery and every sensor on it (TPS, CPS, MAP, COOLANT, ETC). Nothing was wrong with any it, I just wanted to make sure everything was in great shape (still have the originals as spares). The springs are so new they aren't even broken in yet (<300 miles on the entire suspension). 102K on the body & frame. Motor was replaced by previous owner with a 98 TJ 4.0 HO and the AX-15 was rebuilt. It is SOA with 87 Waggy D44s with Flat top knuckles & 1 ton TREs. It came from TX and there is no rust on it.
What's wrong with it .... the paint on the hood chipped where the hood hit the windshield (I touched it up but it's not great) and it could use the E350 Master Cylinder conversion ($78) because the 4 wheel disc is a little soft for the heavy ass boggers ... but they do work. Other than that (and the springs not being broken in), this rig is perfect and ready to wheel.
Since I have gotten this rig I have put under 2,000 miles on it. I am selling it because of that exact reason ... With my job, I just don't have the time I thought I would to be able to enjoy it. I took it to Hammond once and had a great time, but wheeling once a year isn't worth keeping a vehicle around for me. The motor runs great and it creeps when you want it to.
10K obo.
I'm in no rush to sell this and I believe I can get over 10K for it, but I am open to offers. No trades. A beat ass 4.0 YJ with rust will run you 5K, add the 98 motor($750), tranny rebuild ($500), axles ($800), steering ($650) lockers ($1400), gears ($400), cage ($500), bumpers ($650), springs ($600), new sensors ($300) and you have over 6.5K. That doesn't include any labor, the tires, bearings, ball joints, anti wrap and all the odds & ends I have listed below or forgotten ... plus the fact that almost all of the maintainence parts on this are less than 1 year old. I even got new front blinker housings.
You won't have to go in and replace everything like I did.
It's not totally updated but you can find more pics here:
http://www.patricksnorton.com/
Armor/Recovery
Sport Cage
Front Winch Plate
Front bumpercut & reinfroced with angle iron
GM 3500 tow hooks
Warn Grill Guard
Rear Bumper/Carrier with 2" Reciever
Custom rear Bumper/frame Reinforcements
High Lift jack mounted in the back
Electrical
CD player (CD just jammed in there recently but the radio function still works)
Optima Red Top
2gaQuick Dissconnect battery Cables
Cobra 19 CB & a 10 Ft whip antenna
Kill Switch
Off Road Lights
Additional fuse block for accessories
Engine/Drivetrain
1998 TJ 4.0l & Intake (~75K on it)
AX-15 5speed Rebuilt (<15 on rebuild)
np231 w/SYE & CV Shaft
Tom Woods front shaft with grinding on the CV (about a 30* operating angle ability) Just installed last weekend
Front Axle: Waggy D44 with 4.56s & an OX locker (put in less than 5K ago)
Rear Axle: Waggy D44 with 4.56s & an OX locker (put in less than 5K ago)
Front Axle pushed up about 2"
Chevy Flat Top knuckles with a Sky Manufacturing Arm
Warn Hubs
Rear disk brakes with wilwood prop valve & e-brakes
Sans Muffler (might need one for inspection)
Gutted Cat (passed inspection)
ALL vent lines (axles, tranny & t-case) extended to hood or higher
Body
Lebaron Turbo Hood Vents
Wipeboy wiper conversion (they are horizontal now)
Flush Factory Tail Lights
Rampage Half Cab top
Bestop bikini top & windjammer (in addition to half cab top)
Bestop Sliding Uppers
Bedlined interior
Bedlined half doors
Mirrors moved so that you have mirros w/o doors
Suspension/Steering
SOA w/ Rubicon Express 1.5" SOA springs (<300 miles)
Doetsch Tech DT3000 shocks (<300 miles)
M.O.R.E. YJ Shock Towers
Custom Anti Spring-Wrap Bar (Replaceable Heims) (<300 miles)
3/4" Lift boomerang shackles up front
3/4" Lift custom rear shackles out back
1 Ton Chevy Tie Rod & Drag Link with TREs (massive)
Warrior steering box brace
Wheels & tires
15x10 black steelies
35x14.5 Boggers (I'd say about 80-90% tread but they have been grooved)
35x12.5 ProComp MT (for spare - <100 miles on it)
Misc Accessories
APC/Grant steering wheel
Bling shift knobs
Rearview mirror with map lights
Contico Rear Tool Box mounted uner the rear cover
Center console
Other parts:
Spare axle shafts front & rear (new rear bearings pressed on 3 months ago)
RE Hand throttle (NOT INSTALLED still in box)
New Extended E-brake cables (new not installed)
Lots more pics on my website:
10K obo.
Armor/Recovery
Sport Cage
Front Winch Plate
GM 3500 tow hooks
Warn Grill Guard
Electrical
Optima Red Top
Kill Switch
Off Road Lights
Engine/Drivetrain
Warn Hubs
Body
Bedlined interior
Bedlined half doors
Suspension/Steering
Wheels & tires
Misc Accessories
Bling shift knobs
Center console
Other parts:
