akendal4
- Greensboro NC
Is that a rear 60? I have leaky outer axle flanges for a while and tried to fix it for a while. I found out the bolts were toast and kept working there way loose after every ride. I replaced all 16 with grade 8 bolts and washers and RVT'd them and they are currently holding. You going to be at URE Saturday?
I have one stud that has stripped and I drilled a hole and plug welded it into the hub. It's all holding now well now. I came over and said hello yesterday but only saw you one other time before I left and that was just in quick passing at the double parking lot. I'll be back out there with whole weekend for he jamboree.
