99XJLove
- Grand Junction, CO
Okay so I just installed 4.88 gears in my 99. I have been searching around and from what I have found I need a 39 or 40 tooth gear to compinsate for my gear swap. I'm running 33" tires and also have a ax-15 trans. Not sure if that makes a difference or not seeing as how the ax-15 and auto's came with different gear ratios from the factory (3.55 - 3.07) Also where should I purchase one without giving away a teste?
