OutkastBoss
- Saint louis
I got no #'s for ya but here are some opinions about my experience running 4.56 gears with 31" tires on my auto XJ for a few years before stepping up to 33's.
Stock gears and 31's wasn't bad but it did feel a bit underpowered and 4low was used TONS.
My 4.56 gears and 31's were fine for years of Daily driver duties and great with the trailer. I don't usually go more than 5 over but it could handle 10-15 over pretty well on the highway on long trips. In busy traffic it jumped out and took off from a stop VERY quickly. We have lots of stop signs at the bottom of steep hills here, I loved how I would down shift and people think my brakes are out until I am at the stop sign easing to a stop.We towed it over a steep mountain pass in co and even towed 1,000 miles to Moab and wheeled with and without the trailer with that setup. For the years we ran this setup we only used 4low on a couple of spots and almost exclusively with the trailer. when we used it it wouldn't be for long because we couldn't keep up with the group who was in 4low.
It drives better all around now that I have 33's and handles the highway better. I feel like it is still a bit lower than it was stock and still have some of positives of being a little lower geared but not to the exaggerated extent where it causes all the negative effects on road driveability or making 4low virtually unecessary. It does not feel underpowered like it did with the stock gearing and 31's.
We towed the trailer to Winterfest after the 33's and it did great and wheeled up some pretty crazy stuff and it still had the pull needed for the trailer. 4low is back in regular rotation and is way more useable. Then we towed it to and from Harlan and the hills around the black mountains made me miss the extra oomph I had with the 31's but it did the job.
What mileage did I or do I now get? Hell idk its probably not super great being a lifted shoebox covered in steel parts/bumpers/etc. If I did not wheel anything harder than hunting trails I would run 31's and it would be a tough call as 4.10's would be great for around here and even in the Ozark "mtns" it would be fine and have better all around driveability. However when I visit my parents in Co there is plenty of long inclines some of which are VERY steep. (which reminds me add a trans cooler to your rig). If I lived there I would do 4.56's and 31's on a hunting rig.
for a hunting rig that makes I would lean to 4.10 for my area and use. If you go up in tire size later you will regret 4.10's though so keep that in mind and build it to suit your needs/terrain!
