IMO.... The "smooth" runners of the late model manifold will flow the air charge faster than the old style manifold. If you were to grab an Engineering Handbook and look up the properties of a fluid traveling through a pipe, you will find that the sharper the turn in the pipe, the more turbulence is setup at that point. Turbulence impedes flow.
There are formulas to calculate the turbulence...........
A fluid in a pipe will want to form a vortex running the length of the pipe. This puts the majority of the flow in the center of the pipe. You can see how it is that this mass of working fluid would strike the side of the pipe at the hard 90 turn. This is what generates the turbulence. The working fluid flow will "stall" at this point.
Well, then, you ask... Why did the original designers build the log manifold in the first place? That answer is simple. At the beginning of automobiles, intake manifolds were assembled using standard pipe fittings like you would run water in. Later on, they went to castings but, the basic design had been set as "it works". Yup, it works all right. Not well but, it works. And rather than spend the monies to build better, the inertia of the thing just forced it forward. Look at the early intake manifold and compare it to a manifold from the AMC I-6 that had a carburetor on it. Very nearly the same.
Not good, functional...
It worked so they left it alone.
So then, you have to ask which offers the least amount of resistance. Multiple hard 90 degree turns or, gently continuous bends. I vote for the gentle bends....
There is one other, easy to install, modification that will make a difference. That modification is a Header Blanket. If you have the intake manifold off anyway, then that is the time to install a blanket. The blanket will reduce the operating temperature of the intake manifold.
In my case, it made a 20 (C) degree drop.
There is much said about "cold air" intakes. Truth be told.... As long as the air is drawn from under the hood rather than directly from the atmosphere, the air will be heated. I am a fan of drawing in outside air through an insulated pipe.
