- Rainy side of Washington
You chose well doing this to an old body style XJ. The gauge cluster adaptation will be far simpler than 97-up would have been. Not sure on a bunch of other stuff but you know more than me about most of that most likely...
Speedo/odo - will still work since you're using the stock transfer case and VSS in original form
Fuel/voltage/temp/oil pressure gauges are all individual wire-fed, with commonly available senders.
The only fun one is going to be the tach and it's single wire also, I'm not sure if it's a pulse based signal or a voltage signal but it should be fairly easy to get working either way.
How do you intend to put the NP231 on the A340? Swap tailshafts and tailcones? How are you going to feed the VSS signal to the 2JZ PCM if it needs it for trans shifting + throttle control?
